Like me, IIRC
@chris.knudson, you're a bass player...
I built a mostly stock Rat with two switches, one for clipping and another that includes Gord Tranter's mod for better bass response.
I can go totally stock, add bass and add even more bass.
I can go stock clipping (1N914 / 1N4148), Turbo (socketed LEDs so I can pull them for op-amp only clipping), and Phat Rat (Schottky&Mosfet).
I've heard the Reutz mod is good for getting some bass back, but also that it softens the attack or something, basically changing the inherent nature of the Rat Sound (which is fine because you can dial the Reutz back to stock, TTBOMK).
If you build a "stock" Rat board, I recommend adding a minimum-gain resistor, 'cause stock if the gain is all the way down you basically neuter the circuit completely.
Another mod I did was to reverse the TONE wiring, so it gets more trebly as you turn it clockwise (stock Rat cuts treble as you turn FILTER clockwise).
More mods:
Bumped up the input 22n>220n, coupler before transistor 22n>220n and output 1µ>2µ2. Somebody said that does jack-all, to properly tune the rat you need to adjust the filters — where the Reutz Mod resides.
Whatever, I’ve also seen even bigger increases on other peoples’ modded Rat.
The cap after the op-amp, 4µ7, I went Tantalum to save space in the 1590A, wish I'd known about the Wima 4µ7 FILM-caps at the time for higher fidelity…
Tranter has 3 mods, I opted for his Mod #2, and used Tantalums again to save space.
I used a legit LM308, its stock 30p slew cap augmented by a 60p trimmer. Still need to experiment with it more, dial it up to 93p. Some mods suggest as high as 100p.
3N3 bumped to 4n7
I bumped power filtering up as well.
