Dirty_Boogie
My recent Kliche Mini has a higher noise floor than I'd like. It's definitely not bad, but the noise/hiss/hum is there, starting from about 10 o'clock. Which components would likely be the main culprit of noise? I know it's likely a combination of components, but without replacing/rebuilding the whole board, would, for example replacing all the electro caps with high-end audio grade caps likely make a significant difference? Or source a different charge pump, etc...?
Thanks.
Thanks.
