Sea horse power issues.
SimonSudd
I tried to build a sea horse. I thought I could do the cool mods and have a cool, updated piece of gear, but it's not working right. There is no effected sound or LED light when engaged. I do get bypass sound. Thank you.
These are the mods I was trying to follow.
The one thing that I noticed where my attempt at recreating what Chuck D. Bones created differs is that I didn't know how he added the LED for rate. So, I skipped it. In doing that I wired the switch and LED to the board. Did I wire power to my switch wrong, or something?
I'm still going through different forums and troubleshooting guides. I have to get a battery for my multimeter and then I'll be able to do more.
Thanks.
So, I was trying to measure power and saw a little spark and afterwards there was no longer silence when I engage the effect, but it's the same sound as bypass sound. What did I break? Thanks.
Sounds like you touched the negative and positive leads together by mistake.
Have you measured your ICs?
That makes sense. I think it was the positive from the board to the dc jack and the ground to the output jack. Thank you. Can I just shoot the pins listed on the schematic, or should I look up the pin out of each IC and measure those? Thanks again.
PT2399
1. 4.97
2. 2.49
3. 0
4. 0
5. 2.40
6. 2.47
7. 0.59
8. 0.63
9 thru 16 are all 2.49
TL074
1. 4.36
2. 4.36
3. 3.96
4. 8.72
5. 4.36
6. 4.36
7. 4.36
8. 4.36
9. 4.36
10. 4.36
11. 0
12. 4.35
13. 4.36
14. 4.36
LM324
1. 7.38
2. 4.35
3. Cycles from 6.5 to 2.5 and back
4. 8.72
5. Cycles from 7.25 to 0 and back
6 and 7 cycle from 7.29 to 0.64 and back
8,9 and 14 match 6 and 7
10. 4.35
11. 0
12. 4.35
13. 4.35
Are the ascending and descending measurements relative to the capacitors charging and releasing?
