Solder Preference - Spool or Tube
BuddytheReow
Breadboard Baker
So, I’m starting to run low on solder. I use 60/40. My soldering iron came with a dispenser shaped as a large crayon and keep refilling it. I’m thinking of pulling the trigger on getting a spool of it instead of the multiple tubes. I don’t have a dowel to put the spool on. At least not yet.
What kind of solder do you guys use? Any preferences out there? Thanks!
  • Love
Reactions: fig
I started (and still use) these tubes, never thought I’d be 48 builds in. Always wanted to pick up a spool but thought, “just one more pedal I don’t need a huge spool”. 600 tubes later…. Lead free Kester. I know I know but it is what it is.
I use an old set of helping hands to hold my solder spool and my solder wick ... and usually a spool of whatever wire I'm using for a build
I buy solder in tubes, as it's easier to hold on to than having a big spool.
I've stuck to using either MG Chemicals 4860 or Kester 44 (both are 63/37). They both work great, but Kester costs a bit more (and has a better smell).
I use a spool and wind off a stretch, like Barry described, then wind it back up when I'm done. I think you might want to try a tube of 63/37 and see if you like it better before upgrading to a spool.
I use a spool and hold the spool in my hand to guide the 3-4 inches I have unwound. I keep a bit of plastic wrap around the spool to protect my hands. I dont touch the actual solder with my hands.
I end up touching solder a lot despite my efforts not to. I think since it's an alloy it shouldn't be too bad (lead will be inert)? That's what I tell myself anyway, and I hope it's alright. I do wash hands every time I stop soldering.
I use D-Wipes after playing with solder. It's some kind of peace of mind.
I use a spool, as I have done for 20+ years.
I'm not saying you should, I'm just saying I do. :ROFLMAO:
I wash my hands when I'm done soldering... religiously, to a fault... but I suffer a bit from obsessive compulsive disorder so I also wash my hands after doing pretty much anything... including showers and washing my hands. (sad but completely true)
