Shorting is different fromI think Switchcraft 12A is what you're looking for?
Are you going out from at amp to a 2x12? Because I’ve always used a 12a with the shunt tip. I’ve never done stereo setups so it might be different.The 12a shunt tip makes contact with the tip when nothing is connected, bit the sleeve is always making contact connected or not. I think i would need the sleeve as well and not just the tip shunt of the 12a. I might be wrong, whicj is why i ask![]()
Shunt on the tip and shunt on the ring would be the 14BThe 12a shunt tip makes contact with the tip when nothing is connected, bit the sleeve is always making contact connected or not. I think i would need the sleeve as well and not just the tip shunt of the 12a. I might be wrong, whicj is why i ask![]()
Shunt on the sleeve is what im wondering.Shunt on the tip and shunt on the ring would be the 14B
1/4" Stereo 3 Conductor Jack w/Nut & Washer, Double Closed Circuit | Switchcraft
www.switchcraft.com
If the plug is TS, then yes, it is on the sleeve.Shunt on the sleeve is what im wondering.
I guess that makes sense just use the ring as rhe sleeve to shunt it since theres no difference in the connection. For some reason hard to wrap my head around.If the plug is TS, then yes, it is on the sleeve.
I have a 2x12 cab with two 8 ohms wires speakers in parallel i use with my 4 ohm head. I want to be able to plug into the 2nd jack and have it be switched so it will rin just one speaker at 8 ohm.I've read it 5 times but still not 100% on what you're after.
Do you want this on a cab so it runs in mono with 1 cable inserted and stereo with 2 cables inserted?
Not open frame but maybe the cliff CL11607? (datasheet)
Those 11/12 switchcraft open jacks are only rated up to 25 watts(25v 1A)I have a 2x12 cab with two 8 ohms wires speakers in parallel i use with my 4 ohm head. I want to be able to plug into the 2nd jack and have it be switched so it will rin just one speaker at 8 ohm.
Ive got some switched non open jacks. Just for whatever reason would prefer an open face.
Something like the 54AX or 25X would be better suited
