CONTEST Ten Pedals or Less
CONTEST
You guys are reading too much into it, typical engineers ! The answer is 2, based on keywords minimum and typical….
Well, if we're being logical, the title of the thread is 10 pedals or less, so the correct answer must come from someone who's built 10 pedals or less, so I just missed eligibility with my 11 builds
Reactions: fig
Well I‘m on the fence, I built 10 pedals and 12 PCBs ??? What would be your ruling on my case ?
True noob. Like 5 pcbs built, only 3 work haha.
I would say 1. If I can have 2 answers then my second one is 3.
But I have no idea just the varying pcbs I have looked at and or have done have 1 or 3 haha.
Seems most are 1 then 3, and then a lot more than either….
I say 2. Since the LED is a diode and most modern pedals have one.
I have built one pedal, the AionFX Helios. Maybe I should stop buying PCBs and actually build something. I only have around 30, so I have nowhere near the "unpopulated PCB" collections some of y'all have. I don't have a problem. It's not a problem. I need the gift card to buy more.
Another groovy contest! YEAH BABY!
Good morning newbies! :oops:
I must admit I had a few things in mind when I came up with this…
I want to encourage new builders to “think inside the box”. Whether you already had a working knowledge of electronics or started as a lump (like me), the application is key. Once you have familiarized yourself with the common or constants in pedal circuits, learning the less common and unique aspects should become much easier.
Additionally, you’ll make fewer errors on fewer component orders and fewer common goofs when assembling your pedals! This alone can make the difference between a pleasurable hobby or another frustrating money pit.
I left it a wee cryptic which usually sparks further conversation and thought. One of the things that attracted me to this forum (initially lurking) was a presence of civility and a lack of arrogance (ahhh fresh air). You could ask what you might be afraid is a stupid question and actually get the answer instead of ungroovy ugliness. I’m tickled to be part of a growing group of groovy people.
I needed to know how many diodes are commonly found in a guitar pedal 🤪The response I was looking for was 2. The protection diode, which is typically a 2N5817. It‘s located in the power stage, and is most often the very first electronic component that power is applied to. If you accidentally grab that center-positive pigtail, you’re likely given a chance to redeem yourself, as it took the bullet for it’s circuitry brethren. The other is an LED. The oft forgotten status diode. That is, until things go astray. It’s one of the most commonly mentioned pedal components in the troubleshooting threads. “Is my polarity correct?” “The LED isn’t working”.
Okay, so y’all participated as anticipated so the prizes must be emancipated ! Wait, ”prizes”? Yup 3. So let’s break it down;
The FIRST correct answer prize goes to @benny_profane who gave the correct response within minutes of the OP, only to delete said response, having subsequently rejecting himself as a qualified contestant. o_O
The FIRST left-field answer prize goes to @thewintersoldier , and yes I know. I know uno too. 😁
The FIRST correct answer prize by a member having built 10 pedals or less goes to @EGRENIER. Well-done! :love:
Many great responses and it's always good to see 'ol 47 make an appearance. Thanks to everyone for reading and/or responding. Gift codes forthcoming to your respective inboxes. 🤘 Remember to enter the code using the "Gift Code" link/field and not the "Coupon" field.🤠
Now go build something. Why? Because I said so! 😘 :dmm:
This is where you may see some deviation between beginners and experienced builders..
Some of the experienced builders may raw dog it without protection..
Whoohooo, I won !
Thanks @fig, greatly appreciate those contest !
My backlog was already at 7 pedals, looks like it will grow more ! How many pedals does one need to have in his backlog to no longer be considered a noobie ?
Thinking outside the box - you could use a transistor as a diode, there's, usually, a protection diode in a mosfet transistor, a lot of ICs have diodes in them, etc.
Reactions: fig
