Good morning newbies!
I must admit I had a few things in mind when I came up with this…
I want to encourage new builders to “think inside the box”. Whether you already had a working knowledge of electronics or started as a lump (like me), the application is key. Once you have familiarized yourself with the common or constants in pedal circuits, learning the less common and unique aspects should become much easier.
Additionally, you’ll make
fewer errors on
fewer component orders and fewer common goofs when assembling your pedals! This alone can make the difference between a pleasurable hobby or another frustrating money pit.
I left it a wee cryptic which usually sparks further conversation and thought. One of the things that attracted me to this forum (initially lurking) was a presence of civility and a lack of arrogance (ahhh fresh air). You could ask what you might be afraid is a stupid question and actually get the answer instead of ungroovy ugliness. I’m tickled to be part of a growing group of groovy people.
I needed to know how many diodes are commonly found in a guitar pedal
The response I was looking for was 2. The
protection diode, which is typically a 2N5817. It‘s located in the power stage, and is most often the very first electronic component that power is applied to. If you accidentally grab that center-positive pigtail, you’re likely given a chance to redeem yourself, as it took the bullet for it’s circuitry brethren. The other is an LED. The oft forgotten status diode. That is, until things go astray. It’s one of the most commonly mentioned pedal components in the troubleshooting threads. “Is my polarity correct?” “The LED isn’t working”.
Okay, so y’all participated as anticipated so the prizes must be emancipated ! Wait, ”prizes”? Yup 3. So let’s break it down;
The FIRST correct answer prize goes to
@benny_profane who gave the correct response within minutes of the OP, only to delete said response, having subsequently rejecting himself as a qualified contestant.
The FIRST left-field answer prize goes to
@thewintersoldier , and yes I know. I know uno too.
The FIRST correct answer prize by a member having built 10 pedals or less goes to
@EGRENIER. Well-done!
Many great responses and it's always good to see 'ol 47 make an appearance. Thanks to everyone for reading and/or responding. Gift codes forthcoming to your respective inboxes.
Remember to enter the code using the "Gift Code" link/field and not the "Coupon" field.
Now go build something. Why? Because I said so!
