Unnecessary Pad
temol is correct.
Unless you are in Stereo or have a Battery negative lead connected to the Input on this Pad, push the little tab in the little square cutout & pull the Sucker out.
My 2 cents!
That’s a better way to do it than how I just clip off or bend the ends.
temol is correct.
My 2 cents!
why bother?
Because it takes 20 seconds and they do get in the way on tight builds like 1590A where there is no room (usually) for a battery anyways. Also the chance of soldering to the wrong tab is reduced to just about 0 because of the slanted side locating the sleeve tab.
I clip them off. That gives me the additional security of one extra clip on the cable plug but it's still out of the way for wiring,
