KreoPensas
If you have any remaining patience, you can use a method used to turn toaster ovens into reflow ovens. The heating element control is cranked full and the power is switched with a solid state relay based on readings from a thermistor you put in the oven, all run by whatever microcontroller you choose. Might be overkill, but it's on my lazy to do list to find a donor oven and do this for baking paint, polymer clay, etc...Three gaffes this week.
First: I got some cheapo bare enclosures and wanted to try a hammertone finish. Cleaned it up, wiped with acetone, thin coats to start, etc. Did the thing, looked nice. I've heard it said before that baking/heating your finishes helps to harden/cure them so I got a $5 toaster oven at Goodwill and gave it a shot. Well, the five buck oven didn't have any kind of temperature control, just a timer. I figured 15 minutes would be a good starting time. I was wrong. The entire finish bubbled up and melted and cracked and turned into swiss cheese all over. So that one is back to the square one.
Oh well, it's just for fun.
Second: I ordered some parts for a build, needed two 10kB mini pots and one 50kB. I ordered two 50kB's and one 10kB. No matter, had another order to place soon thereafter so went to add a 10kB and I guess wasn't paying attention and didn't see the extra zero; ordered 100kB. I'm sure I can just slap a resistor on it but that's annoying to me.
Third: The aforementioned second parts order... I ended up putting that order together sneakily at my work desk and I guess didn't keep a close enough eye on it. Ended up being ONE cap short and it just so happened to be a value that I didn't have any spares of. Again, can probably patch a couple together and get there, but...ugh
I guess that's what I get for not paying close enough attention all around. Live and learn...![]()
I feel your pain, though.
