So I finally got the time to put a rough draft of a schematic together.
If anyone wants to have a look at it and see if it all makes sense that would be great. In particular the charge pump. Ideally I'd like to go from 9v to 18v and have this as an external switch. Can I use a SPDT per my schematic or do I need to use a DPDT.
I am ideally going for a stock Tubescreamer, but with the ability to add as many mods as possible. I still want to be able to revert to stock if I feel like it. As an explanation of what I have put together, I stole the schematic from the little green scream machine from Robert here. I also added the following:
- Charge pump to run at 9v/18v
- Switch to go from TS9 to 808
- Switch to remove input and output buffer
- A boost that I can toggle on and off with a footswitch
- Order switch to make boost before or after the TS
- Mids control from frost drive/ST9
- Toggle to remove mids control
- Locut from frost drive
- Brightness pot. I got the idea from Aion FX who have a bright toggle switch. I wanted more variety so I have 2 caps in parallell and a pot to vary between them. The karma sutre/anthithesis fuzz has this and I quite like it.
- Gain 1p8t switch per the Palisades/stockade drive
- Bandwith 1p8t switch per the Palisades/stockade drive
I think I really over-engineered this one. I think it's going to be massive.
