What should I put in this box?
Yes I am able to drill it. The middle point is for an LED. I’m thinking maybe 2 one knob circuits just to keep it minimalist.
That's a good idea as it looks amazing. You could always do a cool combo of other boards, but with just one pot on the outside and the the rest as internal trimmer. You can dial it as you like, but then have control over just one aspect of the sound, keeping in the minimalist/one-knober spirit, but still have the option to change the sound a bit later.
Switches and pots in the 4 corners get my vote.
Put 6 separate phase 90 circuits in it, and have them all have the rate slaved to the same lfo so you can all control them with the one rate knob. Then have 6 separate inputs and outputs, and wire it all up for true bypass with a 12 pole toggle switch (they do in fact make them!). Now you’re able to apply luscious phasing to the complete stereo image of all of your favorite 5.1 mix SACDs and DVD-As, and all of your favorite surround sound Blu Rays and 4K discs. You thought the score to Interstellar and Dunkirk was an experience? Wait until you get to experience it in 5.1 with PHASERS!!!!
Yes.
Too small.
Something like this but it's only 38mm
No eq. No blend. Nothing but single knob fuzz action.
I just ordered a 44mm knob for the tone knob of a big muff I’m making. I wanted to order one that was even bigger, but nothing I found that was bigger than that matched any smaller sized knobs for the rest of the controls
This would look amazing with two circuits with trimmers for pots so its a set and forget circuit. You would only need to drill for two foot switches. That would keep it super minimalist. What about a one knob fuzz followed by a boost type circuit?
Bricksnbeatles is a madman.
I like that.
Whatever you build, small knobs all along the top would still look good.
As Jubal81 suggested, a reverb of some sort with delay added — like an Afterneath on steroids.
Maybe checkout DeadAstronaut's delays and 'verbs.
Another suggestion, mount the pots in between the jacks, reverse wire them so they turn "up" to the right.
You could do a Bows (aft preamp) and Arrows (Armentum) Both are simple single knob circuits. I just built the armentum and it sounds so good as a single knob boost that I’m wanting to get the aft preamp as wel
