GizzWizzKing
I can smell the mojo dripping off those TS clones already
I’d suggest working backwards.Do you have any idea how long it would take to tag all of those?
Tagging all the ones that aren’t YATS?I’d suggest working backwards.
Tag all dist/OD as YATS, then untag the 15 bluesbreakers, 27 rat/dist+/250 circuits, and the handful of others that are wild enough to have a baxandall EQ.Tagging all the ones that aren’t YATS?
What if it’s a bYATSxandall?Tag all dist/OD as YATS, then untag the 15 bluesbreakers, 27 rat/dist+/250 circuits, and the handful of others that are wild enough to have a baxandall EQ.
I’d say avoid it and just build a shredmaster.What if it’s a bYATSxandall?
is there a shred master pcb? that's a circuit I always meant to build back when I was going thru my Radiohead phase, but I never actually built one. Never seen one in my searches on the store-- no results.I’d say avoid it and just build a shredmaster.
It’s searchable with “shred master”:is there a shred master pcb? that's a circuit I always meant to build back when I was going thru my Radiohead phase, but I never actually built one. Never seen one in my searches on the store-- no results.
ah. I was searching for shredmaster. ill give them both a go at some point. what's the soldat like? I just like the name bc it reminds me of Stravinsky for obvious reasons lolIt’s searchable with “shred master”:
Also, try this one while you’re at it:![]()
I like it a lot. It can provide a lot of bass presence at high gain without getting flubby or loose. So, it has the tightness of a TS that's good for palm muting or high-gain stuff without the attendant loss of low-end. You can use it for other applications, of course, but that's really the key feature for me. Note that the big-box SDT-1 (AC-powered, integrated boost) is the basis for GCI's Brutalist Jr. Although the tone shaping block is significantly modified in Kurt's circuit.ah. I was searching for shredmaster. ill give them both a go at some point. what's the soldat like? I just like the name bc it reminds me of Stravinsky for obvious reasons lol
If I built the Shred Master it would have a Clipping toggle for 1n4148's/ Nothing/Red LedsI like it a lot. It can provide a lot of bass presence at high gain without getting flubby or loose. So, it has the tightness of a TS that's good for palm muting or high-gain stuff without the attendant loss of low-end. You can use it for other applications, of course, but that's really the key feature for me. Note that the big-box SDT-1 (AC-powered, integrated boost) is the basis for GCI's Brutalist Jr. Although the tone shaping block is significantly modified in Kurt's circuit.
Haha, mine has 1x1 Si / 2x1 Si / LEDs.If I built the Shred Master it would have a Clipping toggle for 1n4148's/ Nothing/Red Leds
DI daughterboard?
Invisibility ring?DI daughterboard?
