What's on the workbench?
I love the way that the signature pedal of a random British christian rock band I grew up listening too is a desirable thing now!
Bear in mind that unlike the States, religion isn't a big thing and "Christian rock bands" have about the same following and cultural clout as skiffle bands do in 2025....
Anyway, I think it's an expandora with extra options isn't it?
All three outputs are simultaneously active, only one is controlled by the expression input jack at a time. (Selected by the footswitch)
I haven't set their initial power-on inactive states yet, they just default to zero at power on at the moment... Once powered on though, all outputs hold their position regardless of whether they're active or not.
It should be here within the next couple weeks.
@Robert How's the programming going for this? I really think this one is going to be a game changer.
Yep, that's basically it, there's also a boost with pre/post order switch.
There is a schematic available and while it's not too far off I suspect it's a best guess and not an actual trace of the Kilt. The Low Cut switch is missing and some of the component values are different... They do match the original Expandora and they aren't significantly different, but enough to suggest the schematic might be a copy/paste job rather than a trace of an actual V1 Kilt.
