Guardians of the analog
Papi Fuego
So are the BBD and clock chips on the back side of the board?
I don't understand how this makes a latte.
I imagine you’re up to your neck in builds but from what I remember reading on the Darkglass Omicron it’s (supposedly) emulating a Blackstone MOSFET into a Boss ODB-3, Jon Stockman’s bread and butter for a whileEventually, yes.
Ooh! Something I’ll actually use a lot!
I’m assuming the footswitch cycles between which expression out is active— how is the inactive state set? Always low/high?
So you can set a value with the expression pedal, then switch output and set the next value? Nice!All three outputs are simultaneously active, only one is controlled by the expression input jack at a time. (Selected by the footswitch)
I haven't set their initial power-on inactive states yet, they just default to zero at power on at the moment... Once powered on though, all outputs hold their position regardless of whether they're active or not.
It should be here within the next couple weeks.
Have a way to set it to different expression pedal standards?
Awesome! That’s exactly what I was hoping as far as holding position— just worded it kinda funkyAll three outputs are simultaneously active, only one is controlled by the expression input jack at a time. (Selected by the footswitch)
How’re those caps looking?
Probably a double version in a cream enclosure.I don't understand how this makes a latte.
Well, I found a few differences compared to the one I traced, but that's irrelevant because what you see on FSB is only a small part of the big picture.
This is what was traced.
Some sort of FET preamp?
at least it's not a guvnor
