I’ve had good luck with my Weller W60P temp controlled iron, which I’ve had for over 20 years now. Temp control protects delicate parts, but the 60w element means it will recover faster from soldering ground wires to back of pots on guitars, or ground busses in amps.
Only downside I’ve found is that you MUST use their specific stand as the temp control is magnetic and cheaper stands could cause it to overheat- but even that’s held up well.
Still on my original tip! Only thing I’ve had to replace was a few weeks back I finally had to replace the sponge in my stand.
As someone who cheaped out on irons before dropping the $$ for a good one, I will again repeat the sentiment: buy once, cry once
