First In, First Served!Dang it! I knew I should of rage ordered at work when I had it in my cart. This one I almost considered buying the real one.
1 pole 12 position switch? Alpha SR2511 work?More are on the way, this was a small prototype batch.
This one needs to be the 1 pole - 12 position adjustable type so you can restrict it to 9 poles.The PCB was designed for the SR2612F type rotary switches. (or SR2611F with the solder eyelets clipped off)
Indeed it isAwesome, really looking forward to building this one. Does anyone know if this circuit is a PLL? I thought I had read that somewhere, but can't find it now.
Yeah definitely am gonna wait and finish my 4th of July order before ordering one of these too xD. Kinda glad they sold out fastApparently not available right now. It was until I went to add to my cart. I was too slow. Maybe it was a sign I need to build what I already have.
Here's a good read! :Awesome, really looking forward to building this one. Does anyone know if this circuit is a PLL? I thought I had read that somewhere, but can't find it now.
Based on a photo of the original circuit, is:Very excited for this! What are the ICs?
I feel like they left out Parasit's best PLL- the Into the Unknown. I'm also quite fond of the MultiwaveHere's a good read! :
9 of the Best Compact and Medium Format Schumann PLL Style Harmonizer Fuzz Pedals
Guitar Pedals, Guitars and Amps - contextual overviews and comparisons, insights and recommendationswww.guitarpedalx.com
Saw this and thought they were in stock….I've decided to make an update to the Flock PCB....
I initially wanted to avoid a breakout board for the rotary switch because someone inevitably will install it upside down on the rotary, but after some debating with myself I've decided to go ahead and go that direction.
The rotary switch puts the PCB at a height where 16mm pot pins just barely make it. It's absolutely doable, but a little tricky to assemble.
Washers under each pot (inside the enclosure) can lift them up enough that this is not an issue at all, but in the end I decided it'd just be easier to include a breakout board.
If you received one of the first revision PCBs and would like the updated board just shoot me a message.
Other than the updated rotary, if everything else is the same, I'll be happy to just stick with the first revision. No biggie.I've decided to make an update to the Flock PCB....
I've also updated the rotary switch footprint to work with the solder lug rotary switches available from Tayda Electronics, since the PCB pin mount versions can be harder to find. No lead clipping required!
