Howdy partners! Is there a build doc / parts list for the Schadenfreude floating around by chance? Thanks!
You're in luck, I generally give up if I can't find the problem within a couple of hours. I just don't have it in me when there's a big pile of other boards waiting to be built......Heck no, because then if you fix it you won't want the second one you ordered.
Absolutely not, I'm no idiot.
Well I found one mistake right off the bat, rookie mistake (makes sense since I AM a rookie at this) I put the 1N5817 in backwards....swapped it out and it still doesn't work, sigh.....wonder if I toasted something in the process. Getting 9v on both sides of the diode.
Yah, something else is wrong with it. Ok, returning this thread to it's original programming. I'll shut the F up and start a troubleshooting thread. (Or wait for the new boardAs long as you didn't plug in the wrong polarity power supply that shouldn't have caused any damage.
You have the drill template for the Synchrotrem / Synchrowah?
I just started one, today. Should finish it up, tomorrow. I'd be happy to help troubleshoot. Who knows, I might have to, as well. I'm only doing a couple of mods that shouldn't change anything. I'm balancing the JFETs (Chuck Bones style from his BD-2 mods) and I'm going to use 2N5087 and 2N5088 for the BJTs.Yah, something else is wrong with it. Ok, returning this thread to it's original programming. I'll shut the F up and start a troubleshooting thread. (Or wait for the new board)
Looking forward to the build report! It's a straightforward build, I just probably did something stupid. I also had some questionable 2N3906's (which I soldered). I think I'm going to socket all the transistors next build, soldering in 8 transistors was probably a risky move.I just started one, today. Should finish it up, tomorrow. I'd be happy to help troubleshoot. Who knows, I might have to, as well. I'm only doing a couple of mods that shouldn't change anything. I'm balancing the JFETs (Chuck Bones style from his BD-2 mods) and I'm going to use 2N5087 and 2N5088 for the BJTs.
Any chance for a drilling template/layout for the Recycler?
