Definitely second this request. Mainly for the drill template, I’ve got the board populated.Any ETA on build documentation for the Danae overdrive? (layout, drill template, schematic etc)
How did you populate the Danae board? The PCB image on the website has everything labeled as R1 etc, but I haven't seen a mapping of this back to the parts list.Definitely second this request. Mainly for the drill template, I’ve got the board populated.
The BOM is posted in another thread. And the board itself has the correct components/values on the silkscreen.How did you populate the Danae board? The PCB image on the website has everything labeled as R1 etc, but I haven't seen a mapping of this back to the parts list.
Thanks, I did see the text file, but I'm only seeing component values and quantities, but I don't see what the value of R1, R2, C1 etc if that makes sense.Missing Build Docs / Schematics
I'll get the schematic (and rest of the build doc) posted asap. The wiring is the standard scheme. The Recycler is basically a Crunch Box without clipping diodes. (which coincidentally is one of my favorite settings in the Crunch Captain Deluxe) Appreciate the background on the this one. I...forum.pedalpcb.com
It’s on this page.
thank you - was looking at preview image before - this fills in the blanks for meThe values are printed directly on the PCB.
This isn't shown in the preview image because revisions sometimes happen before the board is released.
Any electros 50v or less should be ok. You may have to lay them over on their side if you think they might be too tall.Any more build docs for the electrovibe mini? Also having trouble finding short parts - most of the linked parts in the parts list are out of stock...is 8mm diameter too wide for the 100 uF caps?
Many thanks. Wow, $1 per cap. Panasonic is proud of those.I used this series for the 100uF, 47uF & 10uF. They are a bit pricey but good caps! I just used a random 1uF I had…they are pretty small anyway.
Is there a schematic for the Aphrodite? I’m not having problems but it’s one of my faves and I’d like to see why.
Could I get the drill template for the Danae?
