Well.... they're upside down like the original. (Collector to ground)
After seeing this post, I opened up the V1 I picked up cheap locally some years back (Ty Segall/Ohsees fan here). At the time didn't know there was a more recent 3-knob Muff based variant of the Fuzz War. Expected to see 7 transistors, but found only 4... Perhaps this is some sort of v1.5 or transition version with the two pots and one trimmer? Did yours end up being the 7 transistor model?Alright.... Let's put an end to this mystery.
I'll verify the trace, all values, and will measure the parameters of all of the transistors.
This has gone on long enough.![]()
But given the aesthetic of the outside.... I wouldnt expect a work of art insideMan every time I see the insides of a DBA pedal I'm like![]()
You're right, the outside is awful tooBut given the aesthetic of the outside.... I wouldnt expect a work of art inside
All that maneuverability and they still can’t get the PCB perfectly centered.What’s up with the fucking GIGANTIC solder pads for the pots and switch?
