@dawson — thanks for the hair-band and pliers trick!
The wood with a slot in it to hold a PCB upright was something I'd never have thought of in a gajillion years, yet made so much sense once I saw it.
Once I used the wood with slot, I couldn't fathom why I thought a "PCB-Holder" was the way to go.
Mind, I've got
most all the contraptions, ie third-hands and PCB holders, and I still use them all depending on what I'm doing and what will work best.
I've got a pic somewhere of me soldering a series of patch-cables together for a friend — a foot-long 2x4 with a half-dozen 1/4" holes in it to hold the jacks in place while I soldered the wires in assembly-line fashion.
After moving back to Canada, at first I had no scraps of wood laying around at the new house — drilling enclosures and all the other sundry scrap-wood uses ... well it was a pain not having any scraps around. I've got lots at the moment now, though.
Here's another trick I started to use:
I tack-solder one leg of the electrolytics, then I go back with the board vertical on its edge and using my thumb to apply light pressure to the 'lytic, I reheat the solder joint lightly and if the thing isn't already seated smack against the board it is after giving it the "thumb-rush". Then I solder the other leg in using the same method — no more wobbly electros!
PS: don't forget this thread folks!
Just in case your like me and love tidbits of "Hey I wish I thought of that" or "that's a great idea" or not so great I think someone somewhere can benefit. I do all the time. For instance here I was told I should clean my nasty ass board with rubbing alcohol ( he didn't really say nasty but )...
forum.pedalpcb.com
