I don't bend the legs anymore. I've made my share of mistakes, and keeping the legs straight makes desoldering a whole lot easier. It also makes it easier to prevent and correct solder bridges.I bend the legs of resistors and caps.
Sockets and anything that has more that 2 leads, I tack 1 lead quickly with my iron, position it while applying just enough heat, then solder everything without forgetting to go back at that first lead.
Togglesand pots, I install them in the drilled enclosure.
Phrasing?Just bend the legs
Just bend the legs
Over their head, if you're looking for more precise directions.Phrasing?
I've joined camp no-bend. I'd rather the components look kind of whack and still be able to remove them more easily. Maybe I was bending the leads too much before, but I do think that painters tape, at least, can keep most things flush most of the time.Just bend the legs
I do a mild bend. Not fully peened over that it’s hard to remove if necessary (although for resistors that cost like $0.01/ea, I’ll snip first then responder- why risk a board for something that cheap), but not just dropped in as well.I've joined camp no-bend. I'd rather the components look kind of whack and still be able to remove them more easily. Maybe I was bending the leads too much before, but I do think that painters tape, at least, can keep most things flush most of the time.
I feel like this is hard to achieve. A slight bend will keep the component from falling out, but the component will still fall down at least a few mm. The only way, in my experience, to prevent that is to bend the leads quite a bit, and then the components become more difficult to remove if needed.I do a mild bend. Not fully peened over that it’s hard to remove if necessary (although for resistors that cost like $0.01/ea, I’ll snip first then responder- why risk a board for something that cheap), but not just dropped in as well.
I bend just enough that they don’t fall out AND are making good physical contact with the pad
I usually pull the leads and bend a bit (15-20 degrees?) until I’m confident the component won’t fall out.I feel like this is hard to achieve. A slight bend will keep the component from falling out, but the component will still fall down at least a few mm. The only way, in my experience, to prevent that is to bend the leads quite a bit, and then the components become more difficult to remove if needed.
Man this one sent me down a fun rabbit hole. Based on this thread I did buy some orange masking tape but "PCB assembly jig" or "pcb assembly frame" are definitely the better search terms than "pcb holder." John Collier DIY'd one here for ~$100 in parts. A lot documented there is more work than I'm willing to do (and the type of work that I do not do well). 'm on the fence about snagging one up for $160 on ebayI did see something that followed a similar concept.
It was a square frame that held the board. You dropped all components in the PCB, laid a sheet of foam over the components and locked the lid on which held them in place. Then you would simply flip over and solder up the board.
Edit: see video linked below to get a better idea. It’s not cheap!
I don't remove components alot but when I do I heat it up and bend it straight. Seems like much less work to me.I feel like this is hard to achieve. A slight bend will keep the component from falling out, but the component will still fall down at least a few mm. The only way, in my experience, to prevent that is to bend the leads quite a bit, and then the components become more difficult to remove if needed.
That just looks like way too many opportunities for solder bridges for me. I just stick them all in, tape them all down, and solder away, timing the legs along the way.Also, one of the benefits of bending the leads for me is that I don't have to have the iron out to populate the board. I populate a little bit here and there and store the unsoldered board in a bag until I eventually get around to soldering it.
View attachment 73376View attachment 73377
I accidentally left a roll of this outside and it rained. When I looked at it all the gel had oozed out of the tape and dripped all over the place. One of those "ah crap" moments......I use the green tape, either Frog or Stikk brand. A piece will last me several builds, and it comes in handy for on the fly drilling templates, writing down what controls are what, or quick notes I don't need to keep around forever
For the way I build, blue tack doesn't work for me- I populate and solder all similar-sized components at once
