Chuck D. Bones
Circuit Wizard
Wow!  Just wow!
			No, I use a thirty years old solder iron (weller wkcp-s) with a small solder tip. The key is the right solder (fluitin 1532/0,5mm) and temperature.The biggest thing that blows my mind is how clean the solder joints are. Are you using some crazy industrial solder gun or just exceptional technique? ?
It's not a polish, it's a cleaner called: Leiterplattenreiniger LR from KONTAKT Chemie.What type of Polish do you use!!!
Taking photos is also a hobby of mine. I always try to give my best...Its so clean it looks like photoshop clone tool was used! Congrats again man this is truly a work of art.
Thanks!Wow! Just wow!
Thank you, I love it clean. I use a cleaner called: Leiterplattenreiniger LS from Kontakt Chemie, germany.Absolute perfection dude! Love to know how you get the pcb so clean after soldering.
Sounds like some serious stuff. Results are phenomenal!Thank you, I love it clean. I use a cleaner called: Leiterplattenreiniger LS from Kontakt Chemie, germany.
I’ll have to check those outThanks! Yes, mostly I use vishay cmf-55 (0,5W). They fit everywhere without any problems.
No, just clean working only. It's a nice hobby.That's sick. Surgical clean!!!
Thanks!That is crazy good!
Hey @Pedal2222 I just found this thread by searching the forum a bit for opinions on what the proper soldering iron temperature IS. I was wondering if you could expand on the above a bit and tell us what temp you set your iron at?No, I use a thirty years old solder iron (weller wkcp-s) with a small solder tip. The key is the right solder (fluitin 1532/0,5mm) and temperature.
Between 325 °C and 345 °C. But, the higher the temperature, the faster the pace of work. I prefer higher temperatures and short soldering times. It's all a matter of practice.Hey @Pedal2222 I just found this thread by searching the forum a bit for opinions on what the proper soldering iron temperature IS. I was wondering if you could expand on the above a bit and tell us what temp you set your iron at?
Thanks! I'm ordering my components mostly from banzaimusic.com in berlin (germany). I enjoy the time building my pedals. For a good result I always take my time.Holy shit that is phenomenal work! I salute you sir! Something to strive for? And where are you sourcing those beautiful parts?
