Caldo71
About 653 degrees fehrenheit, then...that’s about what I’ve been doing.Between 325 °C and 345 °C. But, the higher the temperature, the faster the pace of work. I prefer higher temperatures and short soldering times. It's all a matter of practice.
So @Pedal2222 there’s no risk at that temperature, then, of damaging components? I only ask as I did recently notice upon DE-soldering some components from a PCB how freakin’ HOT those little 6mm long resistors would get when I pinched them between my fingers. Kinda made me fear for their well-being.
I supppose that skinny .5mm soldering wire you recommend helps one get-in-and-get-out a good bit more quickly, though...yes?
