Simple Rely Bypass (Latching) issue
megatrav
I just built my first simple relay bypass board to go along with my recently build Abider pedal. The Abider sounds awesome!
The issue I’m having is that I have to click the footswitch twice to engage or disable the pedal. It does still work, but having to click the pedal twice definitely means something is wrong. I am guessing it might be the footswitch itself?
If this isn’t something obvious, I can also post some pics.
Thanks!
My immediate thought is it sounds like you’re using a latching footswitch. You’re supposed to use a momentary footswitch— it’s just the relay that’s latching. If you are using a momentary footswitch. I’m not sure what it could be, but someone else may know.
I actually didn’t know that they make a latching footswitch that has the 2 connectors. That could be it!
