finding FV-1 chip?
I know a lot of folks are waiting for the Hydra Delay which won't be here until sometime next week, and I'm almost certain the FV-1 ICs won't last through the weekend afternoon...
So, I've opened up the Hydra Delay and Faceplate for pre-orders, just this once. ;)
I got excited when I received the 'back in stock' email for the FV-1 but seems they're all gone - or am I mistaken?
Hot property...
The internal flash memory of the FXCore is a bit of an obstacle in terms of quick EEPROM swaps or pre-programmed/custom algorithms.
Either the FXCore IC has to be shipped pre-programmed (which means you can't just source them from any vendor), each PCB would need USB interface hardware built-in, or the end user will need a programming tool to get the firmware loaded themselves.
Actually this is the reason for the ICP board, just need access to the I2C lines on the PCB to load new programs. FXCore assembler can talk to ICP then plugged into your pedal and it thinks it is a dev board. There are people working on PCBs with the I2C lines on a header just for this reason, just don't ask the lead times on FXCores...
