Bricksnbeatles
Member known well
Two more ring mods?So what are the other two circs that need naming?
does one of us have to go add a load of chase bliss pedals on the wish list now? - I'm sure would be fun and super easy to trace/buildPure Preamp
Kris-Pre — Kris embodying purity and clarity.
Katharós ProenischytÃs—Greek for "pure preamp"
Too bad it's not a Chase Bliss circuit, could name it
"Chaste Blitz"
or for a Chase Bliss thinger (not Pure-related)...
"Chased Blips" — bonus points if you could have an animated graphic on your pedal:
Wocka wocka wocka
I'm pretty sure that as the Dark World is I think FV1 they might not have jumped up to FPGA so quickly. Anyone know
I’ll have one each pleaseIt depends on the pedal.
The Dark World uses a pair of FV-1s along with a PIC microcontroller and 10 vactrols.
The Habit uses an XMOS DSP.
MOOD and Gen Loss MKII use STM32.
Bliss Factory is a PIC with 15 vactrols.
Now these are getting even more interesting… am I a gear snob?It depends on the pedal.
Field Programmable Gate ArrayWhat the hell is "FPGA"?
so in this situation they (not chase bliss) use it to digitally program a set of analogue audio circuits. So turned off it’s a load of components on a pcb with a load of gates, when it loads in the firmware an analogue circuit is created. Change the firmware and a different circuit is created.Field Programmable Gate Array
It's sort of like designing a custom CPU - an FPGA is basically a *bunch* of logic gates (the most basic building blocks of computing), and the connections between them can be rewritten at will (hence the "field programmable"), so it's basically custom hardware that you didn't have to fab and can fix or modify after the fact.
and even though Robert kindly offers ANY of the PCBs as a way of thanks for the name...
PorkinatorHairy Pork / Hairy Porker
Hysterical! But shouldn't the Fuzz knob's label be upgraded to 'Hair' or maybe even 'Pubes'???Ooo ooo…. PLEASE let me name this one!
