BYOC Brown Face stripboard query
I'm trying to translate this stripboard layout diagram to a 3PDT wiring board and my head hurts. Can anybody tell me where on the stripboard to connect the switch board's in and out (BI and BO)?
Annoying. I'm sure you've maxed out the level trim pot?
Yes that’ll fix it but for some reason i didn’t care for the pre or something. Now that I’m thinking about it though I remember mine was version 1 they went back and fixed some things and made it better. Probably best to disregard what I’ve said. Unless you’re building version 1.
I can't get it working anyway. I think I might hate stripboard.
Strip board is a lot easier to troubleshoot IMHO. No hidden traces. What I like to do is take a pic of the back side and zoom in on it. You can see bridges and bad solder joints easier.
Did you look at the schematic for the BYOC Brown Face Tremolo? If so you'll see that it is not compatible with the bypass switch you are using--which is why the stripboard diagram tells you how to wire it directly to the switch rather than just specifying input and output like other circuits.
You should just wire to the switch directly as specified in the layout.
I think there is a way to make it work if you're creative--it would mean not using the LED or resistor and wiring one of the connections directly into one of the led's pads, but at that point, the board isn't adding much value so you might as well skip it.
I guessed that the 3PDT board might be the problem so I rewired it directly to a fresh 3PDT two days ago.
I had a look at the schematic in the BYOC build document. It's practically illegible. In any case, I'm not terribly fluent in that language though I'm slowly working on it.
Yeah, my eyesight is definitely an issue soldering to stripboard. I ordered a magnifying visor, which unfortunately arrived when the board was mostly done. I will concede that the soldering is on the messy side. That said I'm getting continuity everywhere I should, and no continuity everywhere I shouldn't.
The magnifier is great for well-lit close-ups. I'm pretty confident there are no bridges.
Did you build yours on stripboard? Any chance I could see a pic of your switch wiring to the board?
I had a look at the schematic in the BYOC build document. It's practically illegible. ...
That's a pet-peeve — BYOC would often have an illegible schematic in the PDF build-doc, in most cases, with a clean version of the schematic elsewhere on the website — why not just stick the good version in the PDF? IDK.
Here you go, a screen-grab of the PDF for the schematic (the PDF did not upload for me):
The above should be far more legible than the build-doc's schem, and if not...
If you need the original PDF or any other BYOC stuff, hit up @cwsquared for a ZIP-file of the entire BYOC collection.
Additionally, if you need more help deciphering schematics, check out BuddytheReow's heaping helping of helpful self-help handy threads in the TEST KITCHEN...
May be some bits to glean here, too:
Best of luck with your build.
I did not. I made an eagle file from the schematic for a friend who sent me a pcb.
