BYOC Brown Face stripboard query
I'm trying to translate this stripboard layout diagram to a 3PDT wiring board and my head hurts. Can anybody tell me where on the stripboard to connect the switch board's in and out (BI and BO)?
The lugs are numbered like this
1 4 7
2 5 8
3 6 9
Look on the stomp board to see where the solder pad traces are connected to those lugs.
  • Like
Reactions: spi
Annoying. I'm sure you've maxed out the level trim pot?
Yes that’ll fix it but for some reason i didn’t care for the pre or something. Now that I’m thinking about it though I remember mine was version 1 they went back and fixed some things and made it better. Probably best to disregard what I’ve said. Unless you’re building version 1.
I can't get it working anyway. I think I might hate stripboard.
Strip board is a lot easier to troubleshoot IMHO. No hidden traces. What I like to do is take a pic of the back side and zoom in on it. You can see bridges and bad solder joints easier.
Did you look at the schematic for the BYOC Brown Face Tremolo? If so you'll see that it is not compatible with the bypass switch you are using--which is why the stripboard diagram tells you how to wire it directly to the switch rather than just specifying input and output like other circuits.
You should just wire to the switch directly as specified in the layout.
I think there is a way to make it work if you're creative--it would mean not using the LED or resistor and wiring one of the connections directly into one of the led's pads, but at that point, the board isn't adding much value so you might as well skip it.
