Posted this on your DIYSB post too Otomo
I've de enclosured mine seeing as you got my interest back in trying to find the problem
Initially I thought it was a cap problem or the 'variable cap' from reading RG's technology of the wah pedal
The inductor looks to the second transistor like its far side is grounded, through the 4.7uF capacitor. To the inductor, the capacitor kind of looks like it's grounded because its far side is connected to the emitter of Q2. Q2's emitter has a low output impedance and therefore looks like "ground" if you ignore the signal coming out of the emitter. At the junction of the inductor, capacitor, and 1.5K resistor, the voltage looks like the voltage that would happen across a parallel L/C circuit. However - the current through the capacitor is NOT determined by the voltage across the inductor/capacitor, it is also determined by the voltage driving its "ground" side, and that voltage is increased or decreased by the position of the wah pot. If the wah pot setting increases, the capacitor will let more signal current through because the voltage driving it at Q2's emitter is bigger, so the capacitor has to let in more signal current. If the wah pot setting decreases, the capacitor will let in less signal current. A "capacitor" may be thought of as a special instance of ohm's law by the amount of signal current it lets through. The change in the effective current through the capacitor makes the capacitor look bigger to the inductor and rest of the circuit than it really is! We have a variable capacitor!
With it being a crybaby in front of a 4049 distortion I compared the crybaby part to a crybaby schem noted the value changes and also the 82K and 4u7 had changed places but don't have a clue why, and thought maybe that's it Q3 is not getting enough signal when the tone / wah pot is at a certain resistance setting, I think I'm right in saying most wah pots don't use the whole range of the pot and this tone pot fault kinda mimics that with the dead spot being near the start and end of it
Anyway was messing with it today and purely by luck when I was taking voltages it sprung into life when my probe was on Q3 base and as long as I kept it there it was fine right through the dead spot
So I traced it back touching it with my now disconnected meter probe and got audio until the junction of R11 470K and C3 the 4u7
Anyway perhaps the guys with more technical knowledge than me (that'd be everyone) can figure out what's happening I thought maybe it was something to do with the meter circuit but I disconnected the probe and it still came alive when I touched it
