Ferguson1000
Hi guys,
I recently purchased a Death Cap Fuzz Kit by PedalPCB and I‘m having some questions after receiving and checking the parts.
Thank you so much, I hope you can help me out!
- in which of the LED sockets of the board does the LED actually go? In the build docs there are two LED, on the board itself there‘s a circle with A on minus und K on plus. I‘m a bit confused. Does this mean I could use an additional LED? Since all parts are here according to the build doc, what goes into this left over spot?
- I purchased it via Musikding in Europe. For C2, C3, C4 and C7 they sent me electrolytic capacitors instead of the box caps. In which direction should I solder in the electrolytic capacitors? Would it even work with these?
