Double Kliche
Dan0h
2 more Kliche successes. Friends found out I was making pedals, now everyone wants a Klone. I don’t blame them, I’m a huge fan myself. Although, I have also rediscovered my love for the KOT build too.
Side note, I’ve cut a huge amount of time out of the build process. I was using my DMM to measure every resistor before installing, going through the 10 packs to find the best resistor. Yes for each one. I’ve since started just testing one resistor in each 10 pack when a delivery comes to make sure they are the correct resistors, And when I build just grabbing one instead of testing. Huge time savings. There has been no audible sound difference so far. It also cuts a ton of time out when doing two at a time. The little things.
Nice work! I recently decided to only test the first resistor on any unopened set, previously I was testing each one. I was also going through the build doc in order from R1 onwards but now I'm just doing a section of resistors at a time according to the silkscreen on the PCB. Definitely getting faster!
