I am building the ElectroVibe. Is there any polarity to the lamp and the LDRs? It isn't apparent on the parts I have. But on the printing on the PCB there is a line on the lamp area.
Yeah, I saw that some people have encased the LDRs and lamp in a DIY box/cylinder, but also comments saying it's not necessary with a normal build. Would light from the LEDs be problem? It doesn't seem like it would, I will be using bezels.
You can always put a bit of dark card stock inside the pedal over the LDRS to block ambient light from the on/off LED if anything is coming in. Some pedals like the duophase don't even put anything between the different LEDs in the LDR groups. I have seen some suggestions that the randomness of any light pollution there may be a plus instead of a minus. Overall, I think the LDRs in these pedals are very sensitive to low light levels and it is not unusual for the trim pots to be dialed in to create a pretty dim range for the LEDs.
