enrosenzweig
Looks beautiful! I’m excited to get to work on mine. Where in your signal chain do you have it placed?
Last.Looks beautiful! I’m excited to get to work on mine. Where in your signal chain do you have it placed?
Graphic eq you are boosting/cutting direct bands of frequency. This has more of a Q range that you can focus or widen around select bands. The cut and boost of the lows does seem like nonsense but since the cut and boost frequencies are slightly different from each other you are basically able to tighten or loosen the the Q of the lows as well.Excuse my ignorance, but what does an EQ like this do that a graphic equalizer can't?
Also what's the deal with both cut and boost controls on the low freq, wouldn't they just cancel each other out?
Pretty sure the charge pump pumps it up to 18V.Nice build! Finishing mine up maybe tonight.
One question: The Equinox runs on 18V -- does the Equilux run on 9V?
This confusion is my fault. I apologize.Correct. The Equilux should be powered at 9VDC. The required 18V is generated internally by the charge pump.
You could, of course, omit the charge pump if you wanted to use your own 18V supply instead.
Is it just a matter of not installing the chip, or are there jumpers needed, and any attached passives that also get omitted? (No schematic, but even with one I might still have the same questions. I‘m a bit confused about charge pump usage.)Correct. The Equilux should be powered at 9VDC. The required 18V is generated internally by the charge pump.
Good eye dude. I noticed this right after I posted the photo. One of the best parts of posting pics is you can zoom in. This is not the first time my photo discovered something. Lol.Clean work, Dan0h! I'm building mine as we speak.
Just a heads up, it looks like you missed a lug on the far right rotary switch:
Going to possibly answer my second question, but if I’m wrong, I’m sure someone will step in to let me know. The switch info shows the layout for the index. On the circuit board, each switch symbol has a small rectangle along the perimeter—my assumption is that this shows the orientation for the index.Is it just a matter of not installing the chip, or are there jumpers needed, and any attached passives that also get omitted? (No schematic, but even with one I might still have the same questions. I‘m a bit confused about charge pump usage.)
And (unrelated, but also about the Equilux), do the switches used have an indexing pin that should be drilled?
Just make sure you don’t put them on the wrong side of the board like I did my first build. I feel like that graphic should have been printed on the back side not the top side. I orientated mine to that little square. But flipped sides.G
There are no connections to that side of that particular rotary, so no need to tear it back apart to solder the pin.Just a heads up, it looks like you missed a lug on the far right rotary switch:
The silkscreen does show the index, but it's just for graphical representation (unless of course you decide to drill holes in the enclosure rather than clip them off)... The 2P4T rotary switches are symmetrical so it doesn't matter which way you install them.The switch info shows the layout for the index. On the circuit board, each switch symbol has a small rectangle along the perimeter—my assumption is that this shows the orientation for the index.
Yeah the size is the “only” issue with this one. Such a bad ass pedal but doesn’t fit on my board either, unless I kick off two other pedals. I just have it sitting on top of my cab.My pedalboard positively has NO space for this guy and I'm not sure I "need" it but boy do I wanna make one...
...I am in the process of getting ready to start on a bass board, though...
