mcluff
I noticed the lead length differences on the inductors. Assuming they have no polarity (in this context)?
It’s my understanding that while inductors are not polarized components, the “start” side of the winding is often marked because in certain types of high-speed digital designs, small differences can be critical and you need the effective portion of the inductor as close as possible to other parts of the circuit for optimal operating— ie; it is more a matter of optimization rather than true polarity, such as how some non-polarized capacitors still have a marking for the size that should be at a lower potential for noise reduction purposes. I also imagine you’d want the coils to be wired for phase coherence if you were to put multiple inductors in parallel, but idk… this is out of the realm of the small signal audio world I’m familiar with. Anyway, yeah it doesn’t matter in this situation at all.I noticed the lead length differences on the inductors. Assuming they have no polarity (in this context)?
Yeah, the physical inductor has a long and a short lead. Per @Bricksnbeatles above it probably doesn't matter which direction they go in but maybe it couldn't hurt to play it safe and go with your "positive up" approach.Do you mean the graphical representation, or do you have the physical item on hand?
I think the graphical representation on the PPCB page is just a trompe-l'œil
As for the physical item...
I've got the PCB and parts ordered but they haven't arrived yet.
I'll de'Fur' to @Robert on this.
Actually, I think this is the correct datasheet for the part:
Also, while the pic of the Equilux PCB on the store-page doesn't show polarity, I'm planning on populating mine with the positive leg "up" and shorter negative leg down or southward, as per Robert's usual layout of capacitors with polarity.
Is on page one of this thread.Has anyone got a drill template for this one?
Oops.Has anyone got a drill template for this one?
THANK YOU IMMENSELY!Oops.
Here it is.
Is there a drill template yet?
I also could use help sourcing this part. If anyone has a heads up where you can get them in the US, holla at me!Does anyone know where I might source a LND150-N3? I'm digging and digging, theyre out of stock everywhere.
Thanks!
