Chuck D. Bones
Circuit Wizard
This is my take on the Space Spiral (Dark Rift). It was built on a Sea Horse board because that's what I had. Turns out that the Sea Machine and the Space Spiral are very similar circuits. Biggest difference is the range of the TIME (ANIM) control and some of the filtering. EQD did some screwy stuff with the filtering which is easily fixed. I'll describe the mods in the Modifications forum if anyone is interested. This is the unit on which I test-drove the LFO fix. The only other thing I fiddled was the LFO speed range. This one goes from 0.1Hz to 7Hz. The UV LED flashes at the LFO rate and is wired for always on. The aqua blue LED is the ON/OFF indicator. Mounting the LEDs between the controls presented some challenges. I had to use a solder-lug pot for the SHAPE control so it would clear the LED holders. I also had to bend the leads a bit on the SPEED and FEEDBACK controls. The first pic is a fit check.
Fully assembled.
Here is it before painting.
And after.
Fully assembled.
And after.
