swelchy
Finished up a build this week I was excited to put together... Two glory holes in one enclosure. Did the first board with germanium diodes just to give the first stage a different flavor and built the other to the build docs. Have to say this is the first OD from the offerings here I was not happy with the sound... Both builds have a big issue with unity volume. You can tell the germanium clipper one breaks up real soon and has lower output.. which is expected.. but really both pedals lack headroom in a big way.... each one on it's own you have to dime the volume and have gain at 30% to even get unity with the guitars normal clean tone.... with one pedal on you have to dime the volume and the drive to get any boosted volume... then it's just too dirty.... with both pedals on it is just too much and clips out the second pedal bad and it sort of squeels and oscillates in a weird way.. I was excited to have a stackable od that had the option to get pretty dirty if needed... counting this one as a fail and probably scrapping the whole thing.... I did some searching and turns out I'm not the first to mention low output with unity volume on this one.
