Raspymcnasty
After I originally boxed it up, I just tested to see if the LEDs worked with an underpowered 9VAC adaptor laying around until my 2000ma 9vac power supply came in. When I plugged it in I had a couple of issues.
1. No sound when pedal is engaged (bypass works fine)
2. bypass LED stays on (wired it as default)
I want to test the voltages of my IC's as I saw that Aion posted them in DIYstomboxes but im unsure how to go forward since I've read not to touch certain legs of IC's.
Can someone give me some pointers on what to set my DMM setting to in order to start testing my voltages?
I dont want to fry anything since i'm unfamiliar with this AC powered circuit.
I have some initial questions regarding testing.
Do I power the unit while testing?
Do I just keep my negative lead in the test hole (center hole on top right side of the board) then poke each leg?
Just to cross it off, when im looking for continuity on the 3dpt's which ones should have continuity?
My build
AionFX's documents
My build
AionFX's documents
