Thank you sir!BOM is attached.
Is the Skeptical Buffer build doc coming soon? I was about to order the PCB but realized I can't order the parts without the BOM.
So it is! Thanks for letting me know. I must have been looking at a different PCB, thinking it was the Sergeant Fuzz.The actual PCB is labeled. I built mine a mo their two ago. It is excellent. I made the bias external…
That is my only minor gripe with PedalPCB boards, that they have a code (PCB551) rather than a name. A revision number would be nice too.
@Robert mentioned previously he doesn’t name them until they’re practically in his hands. You type something like Ibanez into the search bar and get all the Ibanez pedal, for example.Putting the PCB number into the search bar on PedalPCB.com will bring up the correct webpage for that board.
Is there a cannon fodder MKI drill guide available or can someone point me to a similar board that has one already?
You can use the template for the Powder Blue, it’s a 4-knob layout with a switch in the middle and the LED above the footswitch.Is there a drill guide for the Scenario preamp? The PCB doesn't look like it fits into a 5 or 6 knob enclosure judging from the pictures. 6 knob maybe otherwise, but the switch up top doesn't seem to line up with the upper pots.
Ahh thanks! Doesn't look like there's a Tayda template ready, but I'll try to measure one from the pdf. Good call!You can use the template for the Powder Blue, it’s a 4-knob layout with a switch in the middle and the LED above the footswitch.
Excellent! Looks correct to me, and I've already filed a couple of enclosures a bit to make everything work, so if it comes to that I can handle that too. I have a drill template for the Simulcast, but the switch was a bit too much to one side I think, so I never posted it here.This should be what you need, although I haven't personally verified it yet.
