SOLVED Mofeta bass and treble do nothing
frustrated
This is the second one I built, first one was perfect. My buddy liked it so much he asked me to build him one. It sounds good except the bass and treble controls do absolutely nothing. They 100% work on my first one. Measured the pots, they are working fine, I don't see any incorrect resistors, pretty sure the caps were all correct, some of them the markings are obscured by other components. Where should I look around? What went wrong?
Please and thank you.
Do you have a 100n cap and a wire? If so, you’ve got an audio probe in the making:
I'm not sure that that's an effective way to engage with folks who are trying to help you. Keep on like that and I doubt anyone is sticking around for you
The tone stack comprises C12, C13, C14, R11, and the three pots followed by the coupling capacitor, C15. Please verify that 1) the parts are correct and 2) you have continuity where appropriate. We can't see any values from the pictures you posted. We also can't visually confirm the integrity of your off-board wiring.
Ok, adult Fluke continuity test.
Treble/Bass connectivity:
Lug 1/Lug 1: no
Lug 1/Lug 2: yes
Lug 1/Lug 3: yes
Lug 2/Lug 1: no
Lug 2/ Lug 2: no
Lug 2/ Lug 3: no
Lug 3/ Lug 1: no
Lug 3/ Lug 2: no
Lug 3/ Lug 3: no
Retested continuity between those caps and pots and I'm seeing connectivity.
Since the pedal functions, just not the treble and bass, how would I use an audio probe to find the issue?
Can you verify the connections to the MID pot too? I’m really not sure what to tell you if all values and connections are verified.
Are all pot values correct? Are all traces verified?
You’re describing a situation where the BASS and TREBLE pots are being bypassed and the MIDS pots is behaving as a low pass filter.
Lug 1/Lug 1: no
Lug 1/Lug 2: yes
Lug 1/Lug 3: yes
Lug 2/Lug 1: no
Lug 2/ Lug 2: no
Lug 2/ Lug 3: no
Lug 3/ Lug 1: no
Lug 3/ Lug 2: no
Lug 3/ Lug 3: no
Ok actually I just tried lug 1 to lug 1 again and there is continuity there. Bass and treble lug 1s are connected.
It looks like a break where R11 goes in the circuit might explain the behavior you are having. May be worth another look to make sure the resistor is good even if you have continuity to each end of it.
have you confirmed the pot values for the 3 tone controls are correct? check them with your meter even if the labels are right. the resistance values for the three of them could be a factor if they were swapped into the wrong places.
Ahhh I don't know how I didn't notice it before but I had the 25k in the 250k spot and vice versa. I could've sworn I checked that. Man that was stupid. I swapped them, now it looks like they're working. Thanks guys, as usual, user error.
Congrats! I wish I would have said something when I thought about it a few days ago.
