Any idea where to get the PCB?Yep, Electra distortion.
I’ve seen their one knob fuzz and their diy section on the Electra Distortion. I haven’t seen that pcb on their site for sale. Would the One Knob fuzz be the same?
Sweet. Thanks!Oh sorry no it’s this one
Guitar Boost DIY PCB Guitar Effect
DH Electro Acoustics - Get It Fast - Same Day Shippingwww.taydaelectronics.com
Is the transistor a 2N3904 like in the schematic above? Because it looks like he is using BAT41s for the diodes.Had a go at perf boarding this today - seems pretty on to me (I have briefly played a real Golden Fleece). I subbed R2 for 2m2 (typo?) and left C5 as an empty socket to play around with later. I'm fairly certain the diode combo is correct from an old Instagram post Mythos made.
Couple of gut shots of the High Road Golden Fleece:
Sorry should have mentioned those are pulled from the internet so don't have further details. I'm pretty new to this, how would diode selection influence transistor selection (and vice versa)?Is the transistor a 2N3904 like in the schematic above? Because it looks like he is using BAT41s for the diodes.
If I'm reading the data sheet for the MMBT5088 it's marking is '1Q' as shown in your photo, so it looks like its a 2N5088Well... I was bored. And curious. So I took a stab at it.
There's probably a better way to do this, but I just desoldered all the components and measured them, and then I used a multimeter to check continuity between solder pads. Sadly I seem to have fried C5 in doing so. Maybe someone can make an educated guess at what a reasonable value for it would be.
It’s definitely based on the Electra circuit. I had no clue how many designs are! Seems like a fun one to wire up on a breadboard and play with.
I caught the 2M2 deft's post thanks, and breadboarded it but unfortunately I sliced the tip of my index finger earlier so can't play tonight.I really have no clue . Also, if you give it a go please note the typo for R2. Should be 2M2 instead of 2K2.
