Jbanks
I built the propolis and powered it on. It makes noise, but clearly not enough. It sounds both quieter than bypass and also not enough gain. There’s some spit there, but like level 1 of 10.
I did a signal test and the signal goes all the way through the components. Am I to assume the culprit is one of the 4 transistors that is not doing its job amplifying the signal? Any advice on which one or how to fix it? My first thought is to resolder all 4 transistors but wanted to ask for help first before I make it worse.
thanks in advance!
James
thanks in advance!
James
