I'm still wondering what tayda will do if you order drilling into the threads of the box, but I'm not willing to drop the coin to find out.
I just measured this the other day, but for a switching board with a buffer. I'm still wondering what tayda will do if you order drilling into the threads of the box, but I'm not willing to drop the coin to find out.
I actually need to order a test drilled enclosure that will be unusable afterwards... I'll do it.
Given the results that @vigilante398 got in the mailbox thread, I’d think it’s finally doable nowDid you ever hear back about the slots/squares if its just a 3mm line? I put my slider project on the back burner and forgot about it.
I haven’t checked to see if drills can be combined with the lines to round edges. Anyone know about that?
Been trying to figure this out too. Anyone have cutouts done and able to say for sure?Can anyone confirm if that rectangular cutouts are true to specified coordinates or if there is added margin? I.e., if I were to specify a 10mm x 20mm cutout, would it be that (disregarding changes due to added paint), or do they cut along at path and add some sort of machining tolerance?
If you wouldn’t mind measuring, I’d really appreciate it.I keep forgetting to measure, but visually it looks like the cutout is the exact size of the drawing. The drawing above has 3mm slots and they certainly look to be about 3mm.
I keep meaning to, and keep forgetting to do so when I'm actually at home where my calipers live.If you wouldn’t mind measuring, I’d really appreciate it.
Thanks!Measured and confirmed. The slots I drew to be 3mm are indeed 3mm.
