Harry Klippton
Not Interested
I thought the $30 I spent was badDo enclosures count? Spent like $50 on an enclosure once
I cut one open recently. Glad I didn't remember how much it cost first
Good buy. These spec’d out @I see my favorite transistor of all time! Flat hats for the win!
FYI, these are sold out forever over at SBE. I have a very small stash left but when they’re gone they’re gone!
Whoops….4.51VDC….corrected, thank you sir.Q3 biased to 1.54 v?
I’ll give that a go. It started a bit higher, but I automatically aimed for 1/2 Vcc without checking any docs…You should try bumping that up before you box it to see how you like it.
Collector voltages for Q1 and Q3 are typically > 7.8 vDC for the MK II.
I landed on @ ~6vDC which sounded to be a sweet spot, so a 1.5vDC increase. It really opened up the pedal. Thanks Derek!You should try bumping that up before you box it to see how you like it.
Well.. eventually....
But it's in your shopping card. Should be in your bottom left drawer![]()
What’s it gonna switch?UPS just about had to team-lift my Digi-Key delivery..
Oh I definitely want to see that when you get it together sir.I'm glad you asked!
So, I'm using this JMK Paralyzer to set up the SCHMORG as 2 parallel loops of effects that I can blend together, or roll back-and-forth between during songs:
https://forum.pedalpcb.com/threads/jmk-paralyzer-for-my-schmorg.12003/
It's working great, but I want a way to get all of my effects back into series (sometimes.)
After an hour of sketching, I learned that I'm not clever enough to build this little dream of mine with any less than a 6PDT.
After another half-hour of asking the internet, "Do 6PDT's even exist??" I found this monster on Digi-Key^.
Like a dummy, I didn't even check the measurements..
It's going to fit under a 125B plate, but just barely.
Should've just asked me.After another half-hour of asking the internet, "Do 6PDT's even exist??" I found this monster on Digi-Key^.
You are a crazy SOB and I love you for it…I'm glad you asked!
Anyhow, I'm going to build another JMK Paralyzer with the parallel/series function.
If they came in smaller sizes then I’d definitely be all over them. As it stands, I have some 6pdt and 8pm to functions I’d like to execute in some of my designs that will probably need me to dive deep into the world of microcontrollers and mini-relays insteadShould've just asked me.
I did that search, too, for a project and was elated to find that monster — then I was deflated by the price!
our search skills are so much better, I remember looking for hours if not days — you found it in a half-hour!
I still haven't picked one up, yet. Will have to once the project rises to the top of the queue. Y
I wanted to be able to switch between 2 settings of an LPF, but would require Dual-Gang pots making that difficult — 6PDT would be an expen$ive $olution with lots of Off-board wiring. Same deal with an EQ I wanted to have two settings for — danged dual-gangs!
Then I wanted to switch out control on a PLL for Glide & Sub-root via the 6PDT switch redirecting either of the controls to a footswitch on/off...
6PDT-SCHMORG!
So many uses, I keep finding them — more people should use these 6PDTs, then maybe the price would come down.
Your Fuzz Face is wrong!Next is the Tone Bender Mark 1.5 .
Man, that poor little transistor is caged!
I'm going to buy a bunch of Telecaster replica Top-hat Switch tips and crazy glue them to some 2N3904 transistors — then sell them on eekbay (with full-disclosure, I'm no snake-oil salesman).
