What’s on *YOUR* workbench?
I like kits from time to time when parts are a little more difficult to source.
Sourcing parts is part of the fun ;)But I did not test the tesla transistors I put in this, hope they will perform well... and I think I put the clipping diodes the wrong way 🤦‍♂️
Youch!
What happened to your 6th saddle there?
This is a compact synth that I plan to use for CV sequenced basslines.
Doing these "kit" builds with all the components pre-picked makes me feel like a king- a spoiled damn king!
I is SO JELLY-YES, yes I is.
Bin Wantin' the DESKtrope HyDroNium for very long long times.
Gawt TUnE iN ToKYo this past fall after menne menne yearages, 'tis what taught me to thought of HyDroNium DESKtrope.
Yessages, MOST GASaciously-inducing yourorack is. Must build DESKtrope in buyger bawx, rrrrooomm to MAUDE!
No. You will alter the taper from linear and, depending on how you’re using the pot (i.e., voltage divider or variable resistor), may have some unexpected behavior.
Check out these resources for more information:
Thanks. It’s for the tone control, and it seems to do the job. I ended up finding a B25 not to long after I soldered it in 🤦🏼‍♂️ so I’ll swap it and see what diff it makes.
Appreciate the links!
Edit: looks like I need 2 ~25ks between each leg 👍🏼
What’s the Story, Morning Glory Hole?
