What's on the workbench?
What the hell is "FPGA"?
I'm not up on all you kids' super-slick jingo-slango-jargonium... but I'll take a stab at it all:
FPGA — Fuzz Propagating Germaniuhm Algae-rhythms ... green-thumbed gearheads accessing Germaniuhm's secrets on a photo-cellular level. ​
VACTROL — VACuous(-minded) TROLl that lurks hidden within an online arena known only as TGP (tonally-generic proliferation?)​
XMOS — eXtraneous Monophonic Outbursts of Scratchiness. Must've been one at the pub jam I was in the audience for this past Wednesday.​
DSP — Degraded Signal Perversion... digit it, digit it all to hell.​
STM32 — Sonic Tonic Mangler (affecting also the 32nd harmonic). How this is achieved is beyond my ken.​
PIC — Price Inflating Chip, increases the cost of whatever build it's in, but other than that nobody knows what it does.​
FV1 — Festering Volatility... not good tone.​
Field Programmable Gate Array
It's sort of like designing a custom CPU - an FPGA is basically a *bunch* of logic gates (the most basic building blocks of computing), and the connections between them can be rewritten at will (hence the "field programmable"), so it's basically custom hardware that you didn't have to fab and can fix or modify after the fact.
so in this situation they (not chase bliss) use it to digitally program a set of analogue audio circuits. So turned off it’s a load of components on a pcb with a load of gates, when it loads in the firmware an analogue circuit is created. Change the firmware and a different circuit is created.
The "Treble Bass" control is backwards, should be "Bass Treble" — Freq'n ...
"PARK'N'SLOP"
Robert, add a mids knob...
"CENTRAL PARK"
Then add an LFO switchable to an Envelope detector for the amount of fuzz...
"AMUSEMENT PARK"
You should only work on this on the weekends, while visiting Chicago...
"SATURDAY IN THE PARK"
If you're jumping around on other projects, it would be ...
"PARKOUR"
If you go out for a fancy dinner mid-trace, then it'd be ...
"VALET PARKING"
Too much fuzz saturation in the circuit would turn it into a...
"PARKING LOT"
Golfing with Royalty?
"PAR KING" 🤮
For those curious about what makes this fuzz, well, FUZZ! or combine it with a utility-pedal looper thing whatever...
"NOSY PARKER"
