What's on the workbench?
Looks like a charge pump, two dual op amps, and a JFET
The rotary switch is an order switch, just because I wanted to be quirky...
(And couldn't find a happy place for a toggle switch like the original)
Also just realized I Rushed and forgot to order parts for the thing.... Think it's bad when you forget one part? Imagine forgetting the parts for a whole damned pedal....
Notice it has TWO FOOTSWITCHES?
Dual BUFFER so you can put a buffer on the input of another pedal AND the output, OR
swap buffers around in stereo! OR
run buffer into buffer OR
run buffer into buffer in reverse order OR
Unbuffered input for running older pedals before it, but then you can compensate with two buffers on the output!
I reckon no one got my hint? @Bricksnbeatles? ;) :)
Is it a JFET? Is it a MOSFET? No one seems to know.... (It's a JFET)
Looks like a lot of space for so few components
It's a two footswitcher, enough folks have expressed that they don't love those in vertical 125Bs.
I have to order parts for the thing though, hopefully they don't take 88 years to get here.... (although it'd be fitting)
Does it have some Weight to it? ;)
I thought over engineered buffers were the new big thing for guitarists? I dunno, I play bass, a lot of this goes over my head :D
