benny_profane
Obverse: "If you can read this, you've done a good job!"
Finally, I can box up all my 45s!
That rotary switch adapter is rad!
Is that a charge pump in there ?
Looks like a charge pump, two dual op amps, and a JFETI
Looks like a lot of space for so few components
A buffer?That rotary switch adapter is rad!
Trying to figure out what circuit that could be— no bbds or cmos… 3 (or 2) position rotary, two footswitches, and 4 knobs…
i’m drawing a blank
Unbuffered input for running older pedals before it, but then you can compensate with two buffers on the output!Notice it has TWO FOOTSWITCHES?
Dual BUFFER so you can put a buffer on the input of another pedal AND the output, OR
swap buffers around in stereo! OR
run buffer into buffer OR
run buffer into buffer in reverse order OR
Does it have some Weight to it?The rotary switch is an order switch, just because I wanted to be quirky...
(And couldn't find a happy place for a toggle switch like the original)
Also just realized I Rushed and forgot to order parts for the thing.... Think it's bad when you forget one part? Imagine forgetting the parts for a whole damned pedal....
Oh I got it alright
I thought over engineered buffers were the new big thing for guitarists? I dunno, I play bass, a lot of this goes over my headNotice it has TWO FOOTSWITCHES?
the tRace is wRong?!T-shirts?
(You typography and graphics designers don't come at me, it's just something I quickly threw together while having my morning coffee)
