benny_profane
I'm thinking I want to upgrade to a drill press for enclosures. Looking for inexpensive options that people have had good experience with.
Thanks for the recommendation. It's good to hear that that model does indeed hold up over time.I used one of these for many years. I've used it to drill PCBs, enclosures, press turrets, etc.
Harbor Freight Tools | Whatever You Do, Do It For Less
Harbor Freight buys their top quality tools from the same factories that supply our competitors. We cut out the middleman and pass the savings to you!www.harborfreight.com
I "upgraded" to a larger floor model Porter Cable a couple years ago, the only real advantage gained was the ability to run at slower speeds....
Honestly I think I liked the Harbor Freight drill press better, but it's one of those things... you blow that kind of money on something you have to pretend to like it better.
The harbor freight press is $60 and works fine. Just don’t leave it outside on your balcony when you live a block from the ocean. The main pole gets rusty but still works fine otherwise ??
Ah okay. It’s pretty stable then?
