Hello, I've just built the informant overdrive and it sounds great! But when I disengage the pedal no sound is passing though... I followed the instruction for true bypass wiring. What's the problem?
I think your Input & or Output jack Blue wire connections are touching the corner posts on your enclosure.
Blow up your Picture you posted & you will see how close the Input connection is/was!
Rotate so they are clear & you should be OK.
