The learning curve isn't that steep for very simple designs, several templates already exist if you already have the software.Any chance we could get a section for uv files guys might want to share?
I can’t seem to find the time to learn how to do this. And I’d be happy with basic knob labeling and a pedalpcb name.
See above, learning curve is not really that substantial. Many folks here have created files and uploaded them to Tayda for UV printing without issue following a basic set of best practices.This would be great! As someone who wants to get into using Tayda for UV printing, but is worried about the well-known learning curve for getting the files just right, having some "verified" working ones like the pedal community already does with Vero layouts or Eagle boards would be amazing. I know if/when I ever get a working Tayda file, first step would be to create an easy to modify template for each enclosure size to work with.
I don't think that will produce a usable result for tayda. I know some people have used Affinity Designer for a cheaper alternative to illustrator, but tayda only officially supports PDFs made in illustrator. It has to be vectors that are in certain layers, with white and gloss using special color swatches on a PDF for tayda. If you want UV prints without the special format, I'd get ahold of Spencer at Amplify fun, when I used their UV printing service it was super simple, and you can send raster images, it doesn't have to be vector.I do my designs using gimp, could it be used to produce a valid format ?
Thank you. I create the color artwork layer, then duplicate it once for the white layer and once for the gloss. All four of those used both white and gloss.Those look really good ! Thank you.
Anything specieal for white or gloss layers?
